1 - 2 of 2 Posts
G
My car leans to the left.. well, specifically, the gap between the front/rear tires and wheel wells is about 1/2 to 2/3 of an inch greater on the right hand side of the car... My car was like this a couple months ago, and did not change when I had neuspeed springs and tokico illuminas installed =( I guess I thought it would have leveled out... I dont weigh 500 pounds or anything, which would definitely tip my car to the side... Anyone have any experience with this or any ideas? 97dx...
G
Discussion Starter · #2 ·
Hummm, I have listened to this is the past, from what I can recall your Honda may be created that way. Not all cars are exactly the same from the factory. Mine, for example, is weird in the trunk area, one side is not lineing up with the body of the car and when I fix it so that it does fit, the other side then becomes out of line. I just split the difference and live with it. It is a "bummer" but what else can I do without spending any money?
Sounds like you have the same issue but instead with your fender/wheel clearance from side to side. Now if you had coil-overs you could fix this issue as well as corner balance the car. Now that would be a great excuse to buy a nice set of coil overs!
Robin
1 - 2 of 2 Posts
