1 - 10 of 10 Posts
91 civic hatch
Its coming from the water jacket I'm guessing. I just put a new intake manifold gasket and should I add sealant where the water flows through? If so what kind?
ministry of mayhem!
93 honda integra
did you cleaned the mating surfaces before putting the gasket?
Is the hose snug there? I had a leak coming from that corner that turned out to
be my clamp not tight enough. Was leaking at high RPMs.
94 civic hatch
If u are SURE thats where its coming from. 1 try tightning the bolts more. or 2 use the rtv silicon that is made for water pumps and thermostats. And make sure the gasket is not ripped.
91 civic hatch
Its probly the sealant I used. Ill re-do it 2maro. But where's the right way to put gasket sealant at, on the intake side or the head side?
1 - 10 of 10 Posts
