1 - 20 of 33 Posts
del Sol si '94
gt2871? Or do they have a 2876 maybe
del Sol si '94
I believe a 2871 with a good size turbine housing, and enuff rpm will get you there or close.
gt3071r t25 flanged...i got it yesterday by the way...
i had a gt2560r making 360hp and blew the shit out of her so i went for something bigger!!!
Same as above
At what psi were you running the gt2560r? And what was your setup? That's the same turbo I have currently
Sent from my Autoguide iPhone app
i was running at 26psi...wiseco/ealge/bg/bisimoto 2.4 with full bisimoto valvetrain,no porting,60mm exhaust,cast manifold,stock intake mani,725 id injectors yada yada yada...
i have to say that it had a pretty broad powerband...
t25 housing with .64 a/r i think!!!
thanks. Did you order it from a specific site?
This is my exact set up, only I have the edelbrock intake mani and ported head & OS valves, so I will be looking for a better turbo after its all up and running.
Same as above
I'm surprised it made power so far past it's efficiency threshold. They say 14 psi is its limit
Magnum RT
I think your exhaust may be your bottleneck, not so much the turbo. Have you thought up upgrading to a 3" exhaust? The free-er flowing the exhaust, the more efficient the turbo can be. Either way, those are great numbers!
Yeah i know...pretty much the only thing that i have to upgrade is the exhaust system.
I will try to go to a full 3" exhaust pretty soon.
I didnt push the car too much just a couple times at 2nd gear on 16psi.
I need to go for a tune and will see what happens.
It pulls like crazy and it isnt too loud.i wish it would sound like a gt3076r but oh well...lol
1 - 20 of 33 Posts
