1 - 14 of 14 Posts
insert user title here
domestic.
yes they will fit. i think theyre either 550 or 560 cc size.
you might have to dremel out the inside of your injector seals a bit to get them to fit.
88 ED6
If they're 680cc, they're most likely aftermarket(stock is 560cc).
I would not dremel the seals. Best bet is to just try a different combination of seals/o-rings. As for the fuel rail height, just use washers along with or without the stock spacer. They look pretty similar to stock injectors though.
Lifetime Awesome Member
'89 CRX HF
1 - 14 of 14 Posts
