1 - 3 of 3 Posts
What do I do here?
15 91211-PL3-T01 Damper, Friction (Low)
$10.02 $7.51
16 91212-PL3-T01 Damper, Friction (Second)
The second is OOS everywhere?
Will this work instead? 91212-PL3-008
I heard tabs or no tabs via Transzex. I mine had no tabs, and I dont know what part number is which, Although I can grind them off...
Info:
http://www.d-series.org/forums/transmission-alley/132369-friction-damper-issue.html
http://www.d-series.org/forums/tran...iddle-zc-si-hybrid-trans-build-couple-qs.html
Bone says(id) he doesnt(idn't) use them, but this is for a DD.
S2(4)0 synchros will work in here as well?
Thanks!
Z6/Y8 dampers, grind tabs, install.
1 - 3 of 3 Posts
