1 - 7 of 7 Posts
KSPORT's Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
Kontrol Pro
•36 levels of adjustable damping
•Made from high quality 6061 aluminum with T6 for increased hardness
•Compression/Rebound adjustable
•Adjustable spring perch for height adjustment
•Adjustable body allowing maximum suspension travel
•Pillowball top mount with adjustable camber (not available for some models)
•Monotube high pressure design reduces oil leakage
•Electroplated body for protection from corrosion and rust
•One year limited warranty
Civic - 1988 ~ 1988 - rear eyelet EF - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1989 ~ 1991 - EF - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1992 ~ 1995 - EG - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1996 ~ 2000 - EK - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
CRX - 1988 ~ 1988 - eyelet rear EF - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
CRX - 1989 ~ 1991 - EF - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Del Sol - 1993 ~ 1997 - - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Rally Spec GR (Gravel) or Rally Spec AR (Asphalt)
•Special designed springs for rally conditions
•Extended Piston Stroke
•Reinforced internals to withstand extreme track conditions
•Made from high quality 6061 Aluminum with T6 for increased hardness
•Compression/Rebound adjustable, Adjustable spring perch for height adjustment
•Pillowball top mount w/ adjustable camber (not available for some models)
Civic - 1988 ~ 1988 - EF - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1989 ~ 1991 - EF - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1992 ~ 1995 - EG - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1996 ~ 2000 - EK - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
CRX - 1988 ~ 1988 - EF - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
CRX - 1989 ~ 1991 - EF - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1988 ~ 1988 - rear eyelet EF - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1989 ~ 1991 - EF - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1992 ~ 1995 - EG - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1996 ~ 2000 - EK - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
CRX - 1988 ~ 1988 - rear eyelet EF - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
CRX - 1989 ~ 1991 - EF - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Version RR
•Aggressive valving and spring rates
•Race applications only
•36-way adjustable damping
•Pillow ball top mount w/ adjustable camber (not available for some models)
•Monotube High Pressure Design reduces oil leakage
Civic - 1988 ~ 1988 - EF - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1989 ~ 1991 - EF - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1992 ~ 1995 - EG - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1996 ~ 2000 - EK - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
CRX - 1988 ~ 1988 - EF - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
CRX - 1989 ~ 1991 - EF - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Del Sol - 1992 ~ 1995 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Circuit Pro
•Remote reservoirs for independent rebound and compression adjustment
•Includes shock dyno results, and tuned to your needs
•Designed to reduce friction for cooler shock oil temperature
•Added oil capacity to dissapate heat and improve performance
•860 possible damping settings
•Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
•Pillow Ball Top Mount w/ adjustable camber (not available for some models)
•One Year Limited Warranty
Civic - 1992 ~ 1995 - EG - For all Motorsports - Height/Ride Adj - 860 levels of dampening positions with remote reservoirs - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1996 ~ 2000 - EK - For all Motorsports - Height/Ride Adj - 860 levels of dampening positions with remote reservoirs - Fr Alum Top Mnt / Rr Alum Top Mnt
Version DR
•Valved and sprung for drag racing; Proven to reduce 60 ft and elapsed times
•18 Month Limited Warranty
Civic - 1992 ~ 1995 - EG - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Civic - 1996 ~ 2000 - EK - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
GO TO NOPI KSPORT Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on KSPORT Coilover Systems
91 CRX Si
I so almost bought these instead of my PIC's.
McLOVIN
2002 Civic Si
I LOVED my Ksports on my 93 Legend Sedan. You can get your car SLAMMED or you can set it to an optimal ride height and use the adjustments to "tune" your suspension on the track. Not a bad set of street/track day coilovers, especially for the price!
i on the otherhand cannot slam my car on these....do i need to adjust the spring perch's becaust i have the struts screwed all the way into the strut mount but i still have a 1 finger gap
i had not issues going stupid low on them, way way to low with tons of travel, i love mine they are great dd/autox status, i wish they were a little siffer but i have very little roll and it doesn't beat the shit out of me on the street, i still need to raise my front some i was rubbing all over the play autoxing this past weekend but tehre was two of us in the car at like 200 a pop doesn't help i'm sure
hatch and R6
I to have the same problem with my ride height. they are all the way bottomed out with still a finger gap. They are on a 89 si hatch. K-sport web site says to not adjust spring perch as it can cause the shock to fail. Any ideas or input is helpful.
1 - 7 of 7 Posts
