T
Just wanted to let you all know do not break your knock sensor whatever you do. This thig @ cost, costed me $105.00, wtf, have you seen this thing? Internally it is a stud w/ two tiny wires soldered to the bottom end. Thats genuine honda price, any alternatives???
T
Boostoholic: Agreed.
Get on eBay, buy a compatible ECU without a knock, and chip it to run your maps on that ECU's code... Ta da.
T
I have an AEM EMS, I imagine this will do this??? Do you know??? Guess I never thought it could be done like this, but, hey you learn something new everyday right!!!
T
Hmm, Ya, you should be able to disable knock with EMS.
T
thanks guys. I'll have to load up and check that out.
Goes to hondata screen.
Pr3 ECU, hondata 2b.
adjust idle = Check
adjust fuel map = Check
Adjust ignition map = Check
disable knock sensor = no can do. WTF :)
Anywho, William, I never knew you were on the boards.
