1 - 3 of 3 Posts
Having to redo my wiring for my KS and have done enough research to know it has to be shielded. One side of the shield grounded 2-4 inches from the ECU correct?
Just not sure which of these to get.
OR.
Is there any other thing I am missing besides a new pig tail to the sensor?
I plan to unpin the ECU harness and cut the pin and reuse it as a pig tail. Will that work?
Any knowledge will help here not 100% good at wiring.
Civic/92Achieva H.O.
your white wire would appear to be the better of the 2, second is pretty rigid coax cable with a solid copper core.
The second is actually stranded core.
Do you recommend any others that are cheaper per ft.?
1 - 3 of 3 Posts
