whats the difference between a p05 and p28? i curious too about which ecu to change my d16y4 so i can chip it with a hondata s300
the P05, P06, P28 are all similar...
P05,
add the mod for 4 wire O2 sensor and add a chip kit and it is the same as a P06 with chip kit.
add 4 wire O2 mod, and VTEC mod, and it is eqivelent to a P28 chipped
P06,
add the VTEC mod and it is the equivelent to a chipped P28
if you buy the VTEC/Chip kit mod from xenoncron (good people) they include the 4wire mod for the P05, if you indicate in the drop down you have one.
priceing for P28 vary siginificantly by area, in this area a P05 is usually about $40, P06 is about $50 and a P28 is usually about $100-$125, but you have to rem a vtec kit from xenocron is like $20 so add that to the price of your P05/P06 and you should be good...
OP: a stock P06 should run a D16Y7 fine, with no problems, it will run better with a tune, but will run decent stock...
i have 20k miles on my D16Y5 with my stock P06, similar engine with VTEC E and only have issues when mrs drives it...
sloopy.
