I am looking at possibly boosting my car this summer. I had a boosted sohc a few years ago, before E85 was even available, so we tuned on 91 octane pump gas. I am only looking for 250-275whp on a stock block with block guard and ARP head studs. proper tune and 310's or 440's (whichever my tuner suggests). My question is this. Running E85 with this setup, how bad is the gas mileage really going to decrease over 91 Octane pump gas? I would like to achieve 30mpg still. Is this possible? Or am i dreaming wet?!?
Thanks in advance
With a good running stock block & headstuds 250-275whp will be easy to obtain. You will want to run at least a 750cc injector.....and 30mpg?? I think its very possible! but really only going to see that milage on the freeway, around town, short trips, cold starts 18-20mpg. I tuned a RT4wd wagon with a stock block Z6, did 285whp and ran like a champ.
my car has a Built Z6, crower stage 2 turbo cam, 2200cc injectors, E85 and I get 26 mpg on the freeway and 18 in town. If I take alot of short trips/cold starts, my milage go's down big time!
Yes its true E85 pretty much takes 30& more fuel, I have tuned cars on 92oct then switch them over to E85 added 30% more fuel and "BAM" they are almost fully tuned! However you will need to spend some time on the cold starts, adding cranking fuel & post cranking fuel will me almost mandatory. evan without touching the timing most turbo cars I have tuned pickup 20-30whp!!!!
just by switching to E85, thats been verified with several cars doing before and after dyno pulls on the same day
I think if you have a
good tuner and
E85 sources close to you then use E85!!
