Kevinio's D16z6 Sol
Hello everyone,
I'm Kevin, 26 years old and live in the Netherlands. I'm a senior engineer at DAF-trucks (PACCAR) and member of the board of Honda Community Netherlands. I own a Honda Del Sol ESI with D16z6 engine. The car is almost finished, the only thing I want to do is to solve the problem of oil spilling in my short block. Here is my current speclist of the car:
Owner:
- Kevin Dingemans
Type Honda:
- Honda CRX Del Sol ESI (EH6)
Type engine:
- D16z6
Color:
- B62p (original)
Wheels:
- 949 Racing 15"x7,5J ET42 Nickel plated
Tyres
Front
- Toyo R-1R 195/50/15
Rear
Brakes
- Disk brake swap rear
- NewMG ZS calipers and disks all around 282mm/262mm
- Mintex M1166 remblokken front
- EBC standard remblokken rear
- Goodridge RVS brake hoses
- USDM ITR 1" HRC
- Integra DA 40/40 proportioning valve
Suspension
- BC Racing kit (10K/6K)
- Prothane bushings
- 26mm swaybar front (MB6)
- 22mm swaybar rear (ITR)
- ASR Brace black
- Muteki black wheel nuts
- Ultra Racing 2-point strut bar: front/upper, front/under, rear/upper
- MB6 Subframe brace
Engine:
- BPi Velocity stack with K&N luchtfilter
- Custom intaketube
- 56mm 97'+ OEM Honda TB with Velocity Stack
- B&M fuelpressure regulator
- Fuelrail polished
- Ferrea flat intake valves
- Ferrea flat exhaust valves
- Ferrea Titanium retainers
- Ferrea valve springs
- Edelbrock Performer X intake, modified by myself (cut, created an other shape in it, sandblasted)
- RDX Injectors
- Ported head to Edelbrock, 3 angle valve job, sandblasted, by myself.
- Bisimoto Level 3 cam
- Bisimoto cam gear
- Gates timing belt
- ARP head studs
- P29 pistons
- ARP rod bolt
- Weighted pistons and rods
- Pistons, rods, crank, pouli, flywheel and clutch in line balanced.
- 3,2kg flywheel
- Windage tray
- New OEM ignition
- MSD spark plugs
- Denso Iridium spark plugs
- Hytech custommade 4-2-2-1 header (the real deal)
- Custommade 2,5" uitlaatlijn with Vibrant 200cell custom modified kat, 2x ultra quiet mufflers, and Spoon N1 muffler modified for V-band clamps
- S2000 oil filter
- Sandwichplate
- VDO oil pressure sensor
- VDO oil temperature sensor (welded in sump)
- Innovative alu/red engine mounts
- Complete overhaul (everything new OEM Honda parts)
- Extra ground cables
- QSP catchcan
- Fuel filter replaced
- Bekerom tuned with Neptune
Transmission:
- LSD Motorsport stage 1 streetdisk clutch
- S20 ESI housing
- Ratios:
Gear X 1st: 3.08
OEM: 1.9
Gear X 3rd: 1.535
OEM: 1.25
Gear X 5th: 1.00
S40 Vtec-E FD 3.7
- MFactory Torsen Diff
- Synchrotech carbon synchro's
- Goodridge RVS clutch hose
- Prothane PU bushings
Exterieur:
- Complete overhauled
- OEM Honda EK9 frontlip
- OEM foglights front
- USDM licensplate caps front
- License plate relocater
- Yellow 3000K light
- Honda Jazz washers
- MS Design spoiler
- OEM 3rd brake light
- USDM license plate panel with JDM fillers (no fog light)
- All black parts painted
- New roof rubbers
- Small license plates
Interior:
- S2000 seats
- '97 model interior(complete black in stead of grey)
- VDO gauge holders
- VDO oil pressue gauge
- VDO oil temperature gauge
- PLX Wideband
- S2000 startbutton
- Chrome cockpit rings
- Momo Monte Carlo steering wheel
- ITR pedals and footrest
Audio:
- Pioneer 4900
- iPod
- Focal 165V2 compo front
To do
- Killswitch
Pictures:
Hello everyone,
Owner:
- Kevin Dingemans
Type Honda:
Type engine:
- D16z6
Color:
- B62p (original)
Wheels:
Tyres
Front
Rear
Brakes
- USDM ITR 1" HRC
Suspension
- Prothane bushings
- ASR Brace black
Engine:
- Custom intaketube
- Fuelrail polished
- RDX Injectors
- Bisimoto cam gear
- Gates timing belt
- ARP head studs
- P29 pistons
- ARP rod bolt
- 3,2kg flywheel
- Windage tray
- New OEM ignition
- MSD spark plugs
- S2000 oil filter
- Sandwichplate
- QSP catchcan
Transmission:
- S20 ESI housing
- Ratios:
Gear X 1st: 3.08
OEM: 1.9
Gear X 3rd: 1.535
OEM: 1.25
Gear X 5th: 1.00
S40 Vtec-E FD 3.7
Exterieur:
- MS Design spoiler
- New roof rubbers
Interior:
- S2000 seats
- VDO gauge holders
- PLX Wideband
- S2000 startbutton
Audio:
- Pioneer 4900
- iPod
To do
- Killswitch
Pictures:
