1 - 2 of 2 Posts
First things first, head out to Staples or Office Depot and go towards the Filing section and find a pack of Filing Folder Transparent Tab Holders...
They usually come in Various colors and are about $1.50 or so...After you pick up the tabs, go home and disassemble your clock and cut the tab holder to the appropriate size and slide it over the clock...After that, assemble your clock back together and cut one of the wires behind the clock...I cant remember which wire it is, but there are three in the back...Ground, power and dimmer switch when the headlights turn on...you want to snip the dimmer switch so that the clock stays bright at all times...Hope this helps everyone...
i just changed mine to amber to match all my other guages and you want to cut the red with black stipe wire. thats the dimer wire.
1 - 2 of 2 Posts
