C
Does anyone know if the black painted or ceramic coated Kamikaze headers are made of mild or stainless steel?
How long do you expect a mild steel one to last from new?
cheers folks
CR-Vtakin
your mom
mine is mild steel with a ceramic coating. the underside of the piping by the flange that comes off the head has a little bit of rust on the underside.
forgot where i got this..hee
"Kamikaze has used the latest technology available to construct a true racing performance header. Kamikaze has constructed a 4 into 1 header that fits stock location. Kamikaze utilizes, 3/8” laser cut flanges, 1 3/4” 14 gauge, mandrel bent primary header tubes that are engineered at just the right length to give you a great response in torque. Our 2 1/2” collector, is designed with the primary tubes joining as they transition into the collector to give more precise management throughout the mid range, The 02 sensors are located at the proper location to read off all cylinders, based on OEM style. Kamikaze went further in constructing a 2 1/2” secondary pipe which maximizes the level of back pressure to give you the overall top end rpm band. Dyno tested and race proven.
Kamikaze headers are available in either, 1200 F. High Temperature Black Coating or High Luster Metallic Ceramic Coating. You can rest assure that every Kamikaze product has been built with pride and quality by a team of dedicated people. Every product is made individually as a professional custom header, rather than a mass production product; giving you the level of quality not always found in the aftermarket.
Fits Honda Civic (2001-2003 DX,LX) "
