1 - 3 of 3 Posts
crx
tonight my alternator belt failed and I drove 30 miles on just the battery ( 6 year old optima red top ) again.
the question is why does the engine run cooler when this happens??
duh
Not enough voltage to run the gauge properly?...
It should still run as hot as the thermostat is set for.
My gauge never moved when this happened to me.
I only went about 20 miles tho.
That, and alternators can put out a crazy amount of heat. I tried explaining to one of my co-workers about how to load test an alternator. Instead of doing what I told him, and revving the engine up to check the voltage, he let the thing idle for about 15-20 minutes with everything on. The alt was hot enough to fry an egg on... So he was whining about how his alt was only putting out about 11v, and I told him to turn everything off before he melted the windings...
But more so that there wasn't enough voltage. If you put a bank of deep cycle batteries in your trunk, you'll be fine ;)
1 - 3 of 3 Posts
