and check the sparkplug because it wont start up so i took the v/c out and find out that teh oil went in to 1-2 spark plugs
and thats why i cant start her up
but how can i clean inside the spark tunnel?
will i have to take the head out and clean it up?
here a pic
Lol rep, pertaining to your vehicle, i say it doesn't hurt to try it, as long and you let it dry before trying to start it again. If it works, hey, free fix. If not, back to the drawing board.
right but how can i clean if those shit r in the way?
it clean em up a lil bit?
maybe take teh head out and do deep clean or its too much of work, but i still need do teh oil change by the way
For real ...if you can get your hands on a slurpy straw get one (the metal ones)...if not let me know ill send you one ...like stated above keep the plug in.
ok i went back outside and clean the sparks tunnel, after that and i pulled the plug and here it goes when i pull it out
theres plenty of oil coming on the bottom of the plug which is teh head am i right?
Ok so I’m trying to tension the power steering pump where it needs to be and realized the car didn’t have part of the items needed to do so.
My question is what other piece do I need to complete this so it will stop squealing randomly?
Portion missing is piece that the wingnut bolt threads into...
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
Hey all,
Long time reader, first time poster.
So, I have a 1995 Civic Ferio Vi, with a D15B (two stage vtec) engine in it. Imported from Japan, so all JDM parts.
But... Something backed off the bolt on my main pulley (AKA harmonic balancer), and it got damaged. So, now to find one.
Partsouq...
