So i put my old b18a1 out of my 91 integra rs into my 94 si coupe.I am using the civic wiring harness, a 94 integra p75 ecu, 94 integra dizzy and all my obd0 sensors other then the o2. i did a lot of reading on this but cant seem to find the answers i need to finish it up.
I want to use my old alt because it works fine. how do i have to splice the wires to use it? the harness has a 4 wire plug and the plug from my old rs harness has only 3. do you spice 2 together? or do you gave to open up the 4th spot in the connector?
will the si's power steering pump work with my 91 rs's mount or do i need to get a 94+ mount to use it.
lastly, what plug goes to the vent things beside my map sensor
thanks in advance
thanks in advance
