1 - 3 of 3 Posts
S
its a d16z6 going to try to drop in a zc but need to find a motor now. can any one help me out. can any one tell me if i will need anything to do this swap like new mounts. it should just bolt in. how about the ecu?
If your running a d16z6 I'm going to assume you have a 92-95 civic since you didn't mention a year.... If this is the case you should try to find an obd1 zc that way it's bolt in and plug and play.... the only other thing you would need is a non vtec ecu....
1 - 3 of 3 Posts
