1 - 4 of 4 Posts
After i take the engine apart and take the head to the machine shop for a resurfacing. Will i need anything to be replaced, such as any bolts that only work once or if any gaskets need to be just replaced or can i use the hardware more than once.
sort of forgot to mention what will be going back into the engine head after resurfcing. Putting in a stage 2 crower racing cam, crower valve springs and retainer kit, with a jdm high preformance adjustable cam gear and timing belt. With these modifications will there be anything i should replace along with it:bong:
As a generic answer what you should be doing is taking your head to the machine shop and asking them to clean/inspect it for you, they will determine if it even needs to be resurfaced and also if you need new guides/seals, have any bent valves etc.
1 - 4 of 4 Posts
