1 - 10 of 10 Posts
look above
i am about to start a new vitara/eagle (fj) build within the next couple weeks. and really i just want to make a list of plans and get your opinions on them,
75.5mm bore for the block still not sure the ptw i wanna run with
bisi 2.4 cam
trying to decide on valve train kit,
aem cam gear, fuel rail, fpr, and if i can afford it water/meth kit
homemade miniram
homemade pedals ( already made them )
homemade tow hooks
turbonetics t3/t4
greddy rs bov
skunk 2 intake
godspeed intercooler 4x12x24
deck the head (havent decided how much)
homemade catch can
full 3 in exhaust
ok so thats my basic list. now opinions please. especially on the stuff i havent made up my mind on. :) thanks guys.
look above
Discussion Starter · #4 ·
cnc laser but pretty close guess. thats what i do for a living. im a draftsman for a machine shop and just draw up parts for the laser, plasma and turret. i make alot of fun parts there. lol
Well.......
hp goals?
head studs?
bearings?
injectors?
clutch?
tune?
a .0035 p2w shoud be fine maybe .004(migh be pushing it, depend on your hp goals)
with a bisi 2.4 it is highly recommended that you run some better springs, i.e.- supertech, bisi, etc. (get springs so you can rev it to 8k without anyworries, just my .02)
stock retainers will work to a certain rpm(i dont remember) but get some ti retainers and youll be fine...
IMHO stock valves will work just clean up the ports or a p&p
regardless of your hp goal your gonna need injectors...
now depending on your hp goals 440 dsm will do to 250-300(correct me if im wrong someone) read the 2ed post in this thread to help you with the injector selection http://www.d-series.org/forums/general-tech/101532-fuel-injector-limitations.html
have you upgraded your fuel pump? if not walbro 255lph is perfect on pump gas ittle run you roughly 100 bucks
hope this helps.....
look above
o yea i guess i forgot to put in all the other info. haha. my car is already turbo'd so i have most of the parts i need. i'm just going for more hp and quicker 1/4 mile times. i want a new clutch. not sure which one i want yet. i already have a walboro 255, i have 550 injectors but i might go bigger, i was thinking supertech valvetrain. i have moates demon that ill tune with chrome. if there is any suggestions on really good tuners near indiana let me know.
08 ZX10
GL with the build man... Def make a build thread and I will be the first to subscribe! This build sounds alot like what I want to do!
BTW I just moved from Lafayette about a year ago!! I used to work with luke, dan, anthony and frito up at the quick lube for like 6 mos or so... Anyway... Good luck man
*** Post up pics of your turbo mani if you haven't already... I'm interested in seeing homemade shit!!
1 - 10 of 10 Posts
