what should i look for in a junk yard motor?...i took the valve cover off, everything looks fine...i took the oil pan off...no loose rods...., no metal shavings in the pan(would they float away if the oil was drained?)...the radiator didn't have any oil mixed into it...i refuse to unbolt the head....is there anything else obvious to look for?
well your not gonna see anything major unless you get dirty. pull the head. look at the sleeves and piston tops., or maybe you find a gem..depends how much your gettin it for.
Exactly Your not gonna find anything out unless your willing to get dirty, I found a Really nicely put together D15b like a year ago, i wouldnt have bought Had I not took the Head off..
then again My buddy bought a b16a from the same junk yard he did the same as you, didnt look the head over,
well its safe to say he still regrets buying that motor lol :bigok:
i dont mind getting dirty...i just dont want to buy a new head gasket and head bolts.......its a 95 z6...could i unbolt examine...and rebolt..with no issues?
can they run it? The wrecking yard I work at we try and run and drive everything, if the customer can here it run from cold and everything checks you get less comebacks. if not get the head off, a hg, timing belt and water pump is cheap insurance and then you have a bargaining chip to. heck bring a bore gauge and really scare umm, my z6 from my yard .006 oval with about .002 taper
I am with everyone else on this one. I would remove the head and check the sleeves and the top of the pistons. A new head gasket and head studs are no more then $150, it will worth it in the long run and the short run to check the Internals out and replace the head gasket.
when i buy junkyard engines i only buy from cars that are wrecked cause you know why its there if there is one thats in decent shape then hmm why would you junk a good car um bad engine perhaps. thats just my theory. ive bought 3 boneyard engines this way and they are all fine. bought an engine from a member here that was supposedly a great engine and got it home and it had a spun rod bearing and a junk crank and the block it about .006 out of round so it was usless with out a complete rebuild
so what i low milage engine cant be abused or run out of oil and be hurt. ive seen brand new engines blow up within 10 mins. if the cars not wrecked there's got tho be a reason why its there 9 times out of 10 is ethier bad engine or bad trans but a junkyard that keeps good track of there inventory should be able to tell you why its there
i'm in charge of inventory at the yard in my sig. i love to know why i have a car in my yard, bad engine or trans is most common for straight rigs, don't get me started on all the straight taurus and escorts i have with bad engines or trans or both same with automatic gm's, all my 94 up accords, rollovers, i sell and deal with other yards all the time and it is always chance, bought my 89 ed from the yard 600 cash haven't done much been lazy and lucky, 5spd swap,clutch,exhaust, an upper control arm, tune up and still haven't checked the timing belt and i have had it over a year and drive it everyday, about 10k on it since i bought it, but i have a backup truck and a z6 in the garage, that needs machine work and reassembled and good to go. i'm taking a chance being lazy, a little extra money spent to check is cheap insurance, i would if i could, just strapped lately
i got the motor.....i pulled the head...and everything looked fine, except alot of carbon build up.....but i took a look closer and one exhaust valve was chipped...i didnt care...got the whole thing for 172.26...im just curious where that chipped part went...
If there is no little marks on the top of the corresponding piston (look hard, clean it up) then you will know that the little chipped off piece didn't just get chewed up.
Related Threads
Honda D Series Forum
2.9M posts
63.5K members
Since 2003
