1 - 10 of 10 Posts
Have an issue with my gears- 2nd gear jumps out into neutral when I rev really hard & 'pulse' the throttle- this does not happen always though. Also if I really shift hard and slam 2nd in- problem does not occur. I dont have this issue on any other gear. My car's a 99 JDM Ek3 with an EG8 gear wheel swap. Even though my clutch is new- I did not change the pressure plate which needs changing big time. Can this problem have something to do with that?
Any advice guys?
EX coupe
mine did this too.....sob :(
countershaft clutch side case bearing, walked out of the case, shifting the countershaft and not allowing full engagement of second gear.
Also check the weak upper motor mount......
Discussion Starter · #5 ·
Thanks for the replies Guys.. Bone how do I repair this thing. And what parts would I need? Am I damaging anything by running without getting it done? Also the last time I checked the timing belt side & Airfilter side mounts they were ok. Will check again though.
Normally, just split the case, tap the bearing into place, then stake it with a center punch.......
Discussion Starter · #8 ·
I agree! Kookk this probelm seems to be common. Seems that this has happened due to a mistake when rebuilding the gear box. I dont think any factory boxes would have this issue.
Thanks Bone-your de man!! Rep for you! I'll fix it when I change the pressure plate. Man it looks so simple in your pics. :)
1 - 10 of 10 Posts
