21 - 26 of 26 Posts
go back to your local yard and snatch the plugs from an obd1 civic. then google for the pins. theres 1 person on here (whose been quiet lately) that gets factory pins, but he hasn't released his secrets
Sloppy Jalopy
What if i wire a plug into the green plug of the chassis
Sent from my LG-G710 using Tapatalk
if you want it bad enough..
but what if.. obd2b harness and ecu.. would be like 30 minutes of work with no thinking required ..
do you have the dizzy and harness that came with your car?
Discussion Starter #25
I have an obd2b 99 ex sedan chassis no harness or anything i got it just as a shell. Then i already had a 98 y8 with motor and trans. Conplete swap. Ive tried both obd2a jumper and obd2b jumper. I have the original obd2a p2p. But i also have p28 thats chipped amd i am planning on running.
But when i was looking at the harness i noticed the green plug of the 98 motor harness had more wires in it then the chassis 99 green plug. Was looking at the 99 "A" plug coming off the chassis it had a couple of the same wires that the 98 green plug had.
21 - 26 of 26 Posts
