Can anyone tell me what the charger will fit. I want to install it on d16y8 1999 civic ex
I have issue with belt at the supercharger snout pulley. Belt skips a tooth and runs on 2 ribs. Would adding more washers to upper alt bolt work??? Or maybe I need to shave more off the lower bracket?The pulley on the supercharger in the picture is a 4-rib pulley.
You need 4 things to make it work correctly with the Y8:
3-rib offset supercharger pulley
3-rib offset JRSC crank pulley
Modified lower alternator bracket
Upper alternator spacer (Or a couple of washers stacked together)
So I shaved my lower bracket and belt is good on crank pulley but only 2 ribs at the snout pulley after a short ride. I used 2 washers at upper bolt on alt. Should I shave move on lower bracket?The offset is going to be the difference between the height in pulleys. IIRC this is no more than 5mm.
