I've been so set on getting the fitting issues worked out, that I totally forgot to take into mind the engine torque & movement...
here is the space I was able to create between the pulley and the strut tower while hammering the other day. its not much, so my next question is:
-can I install the ES motor mounts and/or a torque damper? will it help keep the engine moving on that little space I got? or am I better off getting the mounts, taking the SC off again and still hammering out alittle more space?
edit: from what I seen on the torque dampers for civics, they go right where the brake booster and supercharger route thru, so I guess a torque damper is a
NO-GO?
-the area where the pulley is right next to (strut tower), is reinforced and a BIG pain-in-the-ass to bash in with a hammer. my neighbor and I went at it for a good 2hrs, and the metal barely dents since it seems to have a another layer of metal behind it...the space I was able to hammer in measures about 7/32 to an 1/8 of an inch.
here is the space:
~top shot, u cant really see the space
~alittle better pic at an angle
any recommendations?
thanks
T
