1 - 20 of 33 Posts
HONDA
1. is ake booster as you know.
2 if you worryed about that take a hammer to it. push it in about 3-5mm.
trying to find a pic for you now. think i removed it from photobucket. might be on my home pc.
Discussion Starter · #12 ·
You just need enough room to make sure you can change belts.
thanks bro
what he said. you're good man. just keep an eye on your driver side mount, if it goes you might be screwed.
edit: so what are the plans/specs for this warlock?
big plans, going sc + way too much nitrous
1. yeah the brake booster you know the hose that sitting right next to it in the pic????
2. thats close to the same spacing i have I have had no issues.
hammer? no dude the bearings can get damage by doing that.
I will post my setup for you tomorrow so you can see what hose is missing and where to, but I believe that a hose is missing to the intake.
please and thank you
· Resident D-Bag
honda's
he meant hammer the frame not the pulley. if you moved the pulley then it wouldn't line up with the other pulleys.
Discussion Starter · #15 · (Edited)
this is so far what i have, i need to connect all the water houses, fuel houses and the electrical part on the tb
picture number 2 where the thise two houses goes to?
picture number 3 which house is going here?
picture number 4 from where is that house coming from?
4dr ls
2 fuel line and vacuum line
3 water line from iacv
4 i cant tell but i think its the evap can or perg solonoid
Discussion Starter · #20 ·
1 brake booster hose
2 no it wont rub mine didnt and thats how they all fit
i do know that is the brake booster but where it goes connected and in what order?
can you please be more specific in number 2
What motor is this on?
Also what motor did the SC come from?
That happened when I put a y8 JRSC on my z6. I just hammered the frame a bit for peace of mind lol
d15b7 and it came from a d16y8
i cant see it moving from side to side much...it should be fine
thanks!
1 - 20 of 33 Posts
