1 - 10 of 10 Posts
Well its only been 18 monthes since i started this simple little project, but i finally got everything working somewhat well. I purchased the charger used like 3 years ago, and finally got around to putting it on like a year later. Then i spent another year trying to figure out fuel managment issues...wow, All i can say is don't ever think of messing around with map hacks, FMU's or the like. Nothing but a complete waste of time! I finally gave up and got an s300 system from hondata(which BTW, works great!) and got that installed tonight along with the msd that i used to have. I set the timing up and used a factory p28 map, with expanded boost tables and low and behold, it ran half way decent! I currently have 310 cc injectors, with 2 degrees of timing pulled for each lb of boost. I didn't get a chance to hook up the wideband, but the plugs looked pretty rich. I should be able to add some of the timing back in as well. I have the basic 6lb blower pully installed. Preliminary impressions...very positive! The hondata is great, can't say enough good things, boost-vaccume transitions are seemless! Dyno time is coming, would be happy to post the results if anyone is interested.
Thanks for the info along the way
Tim
00' Honda Civic EX
Im interested in the numbers man. Congrats on getting it running right. Pics?
EG3
I would love to see your numbers if you still have them and possibly ask you some questions on your build I've been researching and making compare lists for a similar build on my dz6 hatch..sorry for bumping an old thread ik im new just found it while google searching
Im Bringing TSEXY Back!
^^Look up
WoW dude this is a 5 year old thread?
Its all most 2012. im pretty sure if it takes you 2 years to get your JRSC running properly you need to be beat with a stupid stick!!
EG3
I've only had my hatch for about 2months fk you very much ;).. im just looking for a little insight on a build someone else has clearly done
Meat Popsicle
91 CRX Si
LOL, blast from the past
I'm pretty sure if the guy only has 46 posts and the thread was made in 2006, there's a very slim chance that he will respond to your question
EG3
lol I didn't check his posts to be honest, im glad you posted tho I just saw your build thread its got some of what im looking for before I start my own build thread
1 - 10 of 10 Posts
