1 - 20 of 30 Posts
I know this is a very off motor as far as internals. wondering what I could do to bump compression up from the small 9.2:1 that its at stock.
i know I could shave the head not sure how much I could take off and how much it would raise it.
EG Final Year
Look into flat omni valves they bump up compression by .3
EG Final Year
There's always a thinner HG too but that's all I can think of right now I'm sorta brain dead right now.
Not too many options, milling head, flat face valve and thinner HG, How about PISTONS? Is there any company that makes piston to raise comp in a D15b?
Reactions: Speedjunky01
ex-g (canadian)
hum... d15b i think your only choice of oem piston to bump the compression are the 13010-PMS-A00... from the d17a7 civic gx
with flat valve it should give around 11:1 but i know there is no valve relief on the exhaust side but i read it shouldn't be a problem if the head is not milled and you run a stock gasket.
Discussion Starter · #9 ·
Ihave a spare y8 head. would it bump compression?
1995 Civic EX Coupe
well im pretty sure the Y8 has the thinnest head gasket so try runnin that and look for some higher compression stock pistons
Discussion Starter · #12 ·
wouldnt that kind of be going against the whole "buying a d15b because i want to rev higher" thing? i doubt a stock y8 head will make power past 7k ish....
dont see why it wouldnt....
if anything it is better then the d15b due to larger ports and better quench area.
I may just build thehead on the side hmmm lol.
thanks for the great hep so far guys reps :)
Discussion Starter · #14 ·
but the deck height is not.
just a litle update/question.
I will be replacing the timing belt and pump.
I need to use the p08 belt right? from the Civic Vx(d15z1)
14400-P08-004 012 BELT, TIMING (103RU24 A-555) (UNITTA)
wondering what water pump to order for a JDM d15b.
not true the d15b head is the same casting as the z6 head. factory to factory speaking the z6 head flows better then the y8 head any day hands down
me.......I'd shave the head .035" for the bump in compression and it would retard the cam about 3 degrees.
But the lazier long rod D15, yet to play with.......
PLEASE Machine shop call me before Xmas!
ex-g (canadian)
there's gotta be a d16 piston you shave down a little to get a good bump in compression.
nope...you need a piston that has a maximum of 27.75 compression height... so if you want to improve c/r... only oem piston you can slap is the one i said earlier all d16 goes over the block...
DROP IT LIKE IT'S HOT
2003 Civic Si
The correct waterpump is one for a VX(D15z1)
You need a VX belt correct
Heres a thread that helped me answer al lot of JDM D15B Questions. Hope this helps you just as much
http://www.d-series.org/forums/showthread.php?t=32597
Discussion Starter · #20 ·
yea I was readding over that thred.
not sure which plugs to get somone argues to either get z6 or b7 IDk which ones AAAA lol.
1 - 20 of 30 Posts
