i know lot been asked about these read lot of it trying to rebuild
piston rings found give up on pistons
crankshaft bearing going try sorce
help needed with oil pump just keep getting told there different but d16z6 fits
so whats the difference please this engine be death of me
Discussion Starter · #2 ·
not shore how you had pics
but tuck d16z6 oil pump and striped
same with d15b
nothing different springs piston oil seal all the same
casting number same only thing i can see on in side one number 4 and 21 on some of the bits and other is 18 and 3
Where are you located? If you are overseas, in Asia or Europe for example, these parts may still be available without cross referencing parts. The z6 pump will work on a D15b. If you need piston rings order them for a z6 as well. The D15b shares the same bore as a z6(75mm), however, the pistons themselves have a different compression height (27.4mm vs. 30mm).
There’s good information to be had in the following thread as well as the links within the thread. It’s not perfect but after some investigating you should be able to find the answers you need.
http://www.d-series.org/forums/general-tech/32597-d15b-vtec-faq.html
Discussion Starter · #4 ·
form uk
the z6 rings are different there 1.2 1.5 3mm d15 are 1mm 1.2 2.8mm but found them now
but agree oil pumps are the same i think :)
