1 - 20 of 76 Posts
Civic 2005
Please any body if any one can help regarding 7th generation jdm d15b. Want to know about its ecu as to which ecu best suits my engine.
Civic 2005
Please see this pic its 7th gen not the old 6th gen.
LMGTFY
__________________
totaled. 93 EJ2
NEW 95 ej1
d16y7 block with z6 head
y7 transmission
ls meshies, oem wing, blacked out tails with h.i.d head lights
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
new 95 ej1.
Please see the pic i uploaded
hav uploaded a pic of the engine please see and give suggestions
Asshole
Sorry no information available here. If that really is a d15b you're on your own because the d engines in 7th gen civics aren't the same as the rest and probably nothing is interchangeable.
You really put no effort into searching and neither will I.
Reactions: slo_eg8
h ttp://lmgtfy.com/?q=7th+gen+d15b+ecu]LMGTFY
take the space out of "h ttp" so it looks like "http", copy and paste it into your search bar.
Civic 2005
Discussion Starter · #10 ·
I am done with wiring and ecu just wanted to know about error code 65
Sent from my ONEPLUS A3003 using Tapatalk
Asshole
CEL doesn't flash p codes bro.
Post a picture of the engine block stamp.
Civic 2005
Discussion Starter · #14 ·
Pic of engine block i already posted in previous posts
Asshole
No you didn't. The stamp where it says d15b, not a pic of the whole engine.
\/Your Mom Was Here\/
Vibe GT
P0141 probably needs a different secondary o2 sensor for the d15b ECU. Not 100% on this but I do know that 04-05 computers use a different set of o2 sensors than the 01-03 ECU's.
Civic 2005
Discussion Starter · #19 ·
Replaced the dual o2 ecu with single o2 based ecu. Even could not find the proper ecu for d15b but instead m using ecu for d17a
Civic 2005
Discussion Starter · #20 ·
Just wondering if its consumption will b more then what is supposed to be anyhow i am in testing phases right now
1 - 20 of 76 Posts
