1 - 10 of 10 Posts
i was wondering if the jdm d15b block was the same as the d16z6 i was wondering about if the crank on the d15b was bigger too thanks:TU:
D15b is stage 3 vtec...biggest stroke the 1.6 but the blocks are different
Not all of them are 3 stage, only the `96-2000 are.
D15B uses the regular D15 block with a special crank that has d15 main journal and D16 rod journal and rods.
eh hatch
you're all wrong or not completely correct
92-95 jdm d15b vtec is the only known block with z6 rod journals
92-95 jdm d15b came in a few flavors...vtec...non.vtec...vtec-e
96-00 jdm d15b came in a few varieties...3.stage & vtec at least.
nobody has divulged the 96-00 d15b vtec crank specs that i have seen
the 3.stage has the same crank as usdm d15's...i own one
A lot
:werd:
1 - 10 of 10 Posts
