1 - 6 of 6 Posts
Hey people i need some tech help, a buddy of mines told me i wont be able to use my 89 si wire harness on my jdm d15b is it true, i already bought a rywire obd0-obd1 harness conversion...so wat else is there too get this motor running besides the wire harness how my buddy told me so
see above
obd-0 to obd-1 conversion p28 and four wire 02 sensor. should be all you need. and i thought you would need a vtec dizzy.
crx
you will need to change distributor plugs. extend wires for new map sensor and evap purge control solenois as well as adding 4 wire o2. everything else is the same plugs. stick with your harness. you will also have to change the plug for the coolant temp switch that works the fans. as well.
1 - 6 of 6 Posts
