1 - 1 of 1 Posts
Alright ima try this again...
I posted the wrong info earlier in another thread...
http://www.d-series.org/forums/engine-building/121999-b2-cam-y8-head-help.html
I have a jdm d15b cam in my d16y8 head which is milled .030 over, with a y7 block...
I read that for every .012 milled a retard of 1* is needed??? So since i milled it .030 over i would need to retard the timing 2.5*, correct???
Since the jdm d15b cam is almost the same as the d16z6 cam... and since i have it in the d16y8 head the "half a tooth" theory applies... http://www.d-series.org/forums/engine-building/41363-y8-cam-w-z6-sprocket-z6-cam-w-y8-sprocket.html which means i will have to retard the timing 4.75* correct???
If so would i need to retard the timing to 7.25* for it to be correct, correct???
Any help would be greatly appreciated, thanks...
1 - 1 of 1 Posts
