1 - 1 of 1 Posts
so i figured i would post a thread about my build because when i was looking into this i couldnt find anyone that actually had a write-up of parts they actually had..
i got my engine torn down and bought some vitara pistons and d16 eagle rods off of a guy on craigslist. the pistons say 75mm but measured and found out they are .020 overbore.. :dots: not sure if they were bought knowing this but ill just get it bored.
rod journals are identical and same length before i bought these i couldnt figure out how the pistons were same height from the pin as a d16 when the d16 had a longer throw but later found out its because of difference in the block height.. this set has floating pins. not sure yet but might need to get tops of pistons milled a bit because of pistons sticking past the deck but we will see.
1 - 1 of 1 Posts
