HONDA
whats up D-series i completed a D15B swap today and started it up , its idles good and revs up in neutral, no CEL, im using a chipped P06 to D15B settings, so i go to drive it and the clutch engages, it will chirp the tires in the shop but as soon as i let off the clutch completely the engine bogs down and dosent wanna go. please help anyone had this problem ?
thanks
HONDA
it seems like it does it when you put the engine under a load , and the car kinda jerks but im assuming thats because of the clutch being ingaged and no power
HONDA
ok i need to make some corrections here , im using a chipped P05 ecu , so today i plugged in a stock P06 ECU and the car runs fine, could i have did something wrong when i chipped the ECU. i got a D15B map i found online could someone take a look at it and see if they can see any problems.
