so ive been debating on puttin a 3stage head on my z6 block for a while and wondering.....if i can get the correct ecu (only obd2 right?) how would i go about tuning it?......the school i go 2 in va beach has a dyno and uses the aem ems for tuning purposes.....could i use the ems 2 set ignition/cam timing, a/f ratios and vtec points during all 3 stages(12 valve mode till 2.5k...16 valve mode till 4.5-5k and vtec from 4.5-5k and up?{def setting fuel maps to make the most power with these x-over points}) on an obd2 ecu?.....also.....will the z6 timing belt work?
