1 - 7 of 7 Posts
Hi, Will from NZ here. I completed the swap over a few weeks when the original DOHC ZC went pop. I'm desperately trying to hunt down a part number for the OEM 22 mm crank pulley. Or a suitable aftermarket equivalent. Thanks!
Doubt few here know what a Beagle is :)
Have you tried a NZ/NSW Honda forum, I know there are a few decent ones.
ED6&7. EE4&5, MB1
88 Dohc ZC
13310-PM6-G00 CRANKSHAFT COMP. (22MM)
13310-P2E-010 CRANKSHAFT COMP. (24MM)
13810-PM4-000 PULLEY, CRANKSHAFT
38921-PM7-003 PULLEY, CRANKSHAFT
89 Dohc ZC
That might be a good starting point.
Here is the wildcard: 56990-PM0-T00 PULLEY, CRANKSHAFT (POWER STEERING) (22MM)
88 Dohc ZC
89 Dohc ZC
good evening from Greece,
I am trying to replace the crankshaft pulley on my d16a9 engine as when I bought the engine it did not have a power steering, and my car needs it.
my crank nose is 22mm.
finally the spare part 13810-PM4-000 PULLEY, CRANKSHAFT
is 22mm with position for the power steering belt?
the seller (amayama.com) does not confirm this to me and I am afraid it may not be compatible.
unfortunately 56990-pm0-t00 is not available.
any answer / help would help me in particular.
thank you very much,
Κostas.
89 EF 4wd sedan
13810-PM4-000 PULLEY is without power steering. if you use JPcarparts its a bit more descriptive:
Thank you very much for your answer but I want to ask you Which of these pulleys has a diameter of 22mm because I am confused I want it to have ps
1 - 7 of 7 Posts
