1 - 6 of 6 Posts
00 civic dx cdm
hi i changed the radiator support on my eg but i only bolted it on i didnt weld. i tried jacking up the car but as i was jacking it, it was making some noises and the car wasnt really getting off the ground, so i stopped and opened the hood to see. next thing i know the rad support was bent. it bent as i jacked it. my question is: are those rad supports supposed to be jacked and witstand the car weight? if it gets welded will it work? if not how am i supposed to jack the car? i could jack it on the side spots but the how would i insert the stands?? thanks in advance
you can jack it on the lower control arm mounts and use the side jacking points for the stands. there is a tow hook on the front you can use, but if the front end isn't welded, I wouldn't trust it
Retired From Hondas
you can jack it on the lower control arm mounts and use the side jacking points for the stands. there is a tow hook on the rear you can use
fixed
Why do I have a feeling that the whole front end is a little askew
fixed
you cant use the front tow hook that's bolted to the frame rail? whoops
1 - 6 of 6 Posts
