1 - 15 of 15 Posts
ITB only for NA that wack
ITB's can be us in a turbo application turbo but fabrication of a air box for the 4 throttle bodies which i have seen in many 4age 20v in Hawaii and Cali, but itbs need a modified ecu because the high amount of air so air/fuel maps need to be change. Go Hondata chipping your ecu can help....Its a honda have faith...not a AE86 turbo 4age 20v
The spark timing and fuel maps for ITBs look different than a manifold intake. Tuning is the only way to extract power from ITBs, just slapping a set on there will actually hurt performance.
Look at these two default calibrations that come with Hondata SManager.
ITB spark table- it reaches full timing advace quicker and holds it longer through the RPM range - it's hard to read but if you look closely in the upper left corner of the pic notice this is a TPS based map
Stock P28 spark table- kPa based map
ITB fuel table
Stock P28 fuel table
You can actually "see" that the two 3d maps have different shapes. Every car has unique airflow properties. With a different intake or exhaust the "shape" of maximum performance will change as you add or take away fuel or spark advance searching for more power.
FAMILY MEMBER #316
more air means it need more fuel. plus, the idle will be all fucked up and theres usually not a lot of vacuum for the motor to work off of.
Its not the air flow is how the air flows, normal manifolds have a slow map transition. ITB's have a violent very fast MAP signal on a off throttle so a stock ECU just dumps way too much fuel on throttle tip in. A good ECU will have a throttle/Map blend and or a MAP adjustable transfer rate.
Also ITB's have a very waivy MAP signal from each runner having a seperate MAP pulse, a after market ECU can use a MAP filter to take the adverage of the MAP signal compare to a stock ECU which will constantly adjust the fuel curve with every on and off cycle of each intake runners air pulse.
ITB= Adjustable ECU
Does Crome Pro have this cycle issue covered?
OT:
I dont see people use their IACVs anymore with their ITB setups...
So what does one do to get idle to compensate for a/c?
I only use Electromotive Tec 2, which has a multiple ways to deal with the MAP issues of ITBS. As for the AC issue you can run a factory IAC you just need to be creative with the plumbing. Some people build a vacuum log and pipe the IAC into it so the idle air is fed equally to each runner. I personally dont use a IAC, my tuner can get the car to idle with out one so its one less thing in the engine bay.
ah its hard to understand, and those diagram looks like rocketscince for me^^
but i think i get it
in simpel words
the ecu are too slow to react on the fast itb airflow---->right?
No, they just can't compensate for the irregular MAP readings. Crome's ITB Tools(which uses the stock ECU), uses the MAP only for idle/low vac, then switches to TPS only.
No, Crome(free) still has it. There should be a version already installed under Plug-ins. If not, check the sourceforge directory for Crome or go through the Crome Development section on forum.pgmfi.org (there's an ITB thread).
1 - 15 of 15 Posts
