1 - 20 of 20 Posts
Compressor Housing T3 A/R .42 2 3/8" (60.3 mm) inlet and 2 1/4" (57.1 mm) outlet.
Compressor Wheel : T3 (55 Trim) 1.760" (44.7 mm) Inducer and 2.367" (60.1 mm)
http://forums.ok-speed.com/showthread.php?t=31579
It is a Garrett t3 turbo that someone is selling locally where I am at for $75. I was just wondering if this would be a good match for d16z6. this car is my daily driver and i am thinking 10 psi max boost on stock engine.
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
YOU NEED
pics.
more detailed info about it.
your plans for it.
why they are selling.
racist-bigot-sexist-homophob
Sounds like a standard 42 / 48 volvo / saab turbo. If that's the case I've bought two for around that price before.
ES1 Civic
looks like it, in the link...
ES1 Civic
looks like a volvo to me too.
you guys should read the thread he posted. the guy said it was a universal turbo...and then another guy thinks it's an sc-61....
yea standard volvo .42 .48 it will not bolt directly up to a t3 flange because of the way they came from volvo . you notice how the flange is dished on the turbo ? Well on the manifold that part stuck out so you dont have to use a gasket well that dished circle sticks out around an 1/8 inch on top and bottom of what the flange covers . So you either have to mill the turbo flange down flat or make an adapter plate to cover where that hole sticks out . Ill try and get some pictures of my volvo turbo mounted without the adapter plate to help you understand what im saying
you can get the manifold made with that flange or atpturbo.com sells an "adapter" piece (its actually a hard metal gasket) that will allow you to bolt it to a standard t3 flange with out a leak.
again, call autoworks and ask. i am sure he will be able to help you with adapting that turbo to one of his kits to help you save money.
edit: i am actually surprised he has not posted on this already....
well turns out i was thinking of it backwards, standard t3 on a volvo manifold:
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-FLS-051&Category_Code=FLG
but a conversion could still be done with a flange from bmcrace. by pinning this:
http://www.bmcrace.com/product_info.php?cPath=132_133&products_id=97
between the manifold your going to get and the turbo, gaskets would need to be used. but this is all if you want a standard t3 flanged manifold, highly suggest this, so upgrades could be made later.
1 - 20 of 20 Posts
