1 - 20 of 28 Posts
will it spool? yes
At what rpm? Probably 5-6k.Leaving you with 1-2k rpms lol sounds like a well matched setup.
cliffnotes.Get a diffrent smaller turbo.
42./.48 straight t3
50./63 t3/t4 50 or 57 trim
60./63 t3/t4
talk to autoworks
60-1 is pretty big for a single cam... go with like a 50 trim t3/t4 or something close to that.
R2.....Zap Balls
More like what is your HP goal. No need for an overkill turbo if you only want a little over 200 HP. But if you want somewhere at 400HP+ and go for it. I'm just not sure how long that turbo will last. It'll be a hit or miss kind of deal on that turbo but spooling that turbo is no problem if that is all you are worrying about.
depends on the single cam your dealing with... i know a semi-built f22a4 will spool that with out issue.
op: 50-60 trim (depends on goals, needs, etc) t3/t04 is a very good match for the d engine. check the stickies, there is a post that can help you determine what size will be too big and the approximate tie of full spool. here is a hint someone in your htread posted it ;).
R2.....Zap Balls
Picked up my 50 trim like that up from Greg, great turbo :TU:
dyno sheet for said turbo, this thing will get you to 400 or really close to it at the wheels.
1 - 20 of 28 Posts
