1 - 9 of 9 Posts
crx and ford ranger
that sounds bout right with them low compression pistons
there supose to be within 10 points of each other
ok cool, i was worried cause all the other honda motors that were in good shape under 200k were almost exactly even
91 CRX Si
Did you have the throttle wide open while testing? That will effect the outcome.
Yeah, was the motor fully warmed up?
Fully charged battery?
Same number of cranks?
ya make sure you hold the throttle down and crank motor about 4-5 times same for each cyl
Discussion Starter · #8 ·
i always hold the throttle or have some hold it and crank until it pretty much stops going up. it was warm.
also is it normal for a built d to have a bit of a desiel truck sound to the motor?
Really with a built motor if done right it should be pretty damn close.170-180 might be ok. But 170-190 like he said could be better.
How knew are the rings. Turbo on it.
1 - 9 of 9 Posts
