1 - 2 of 2 Posts
My car...
Been playing around with the Borg Warner MatchBot, and got this as a good fit for my intended goals. Not sure if the turbo can spool to those pressures at those points, but I'm aiming for 200ft/lbs before 4500rpm (closer to 4000rpm) and 350bhp at like 7000rpm.
What does it mean by:
"Is the Wastegate Flow Choked?" and it says "Yes"?
If it's an internally gated turbo, what can you do about it?
http://www.turbodriven.com//performanceturbos/matchbot/index.html#version=1.2&displacement=1.6&CID=97.632&altitude=50&baro=14.681&aat=85&turboconfig=1&compressor=62k80&pt1_rpm=2000&pt1_ve=85&pt1_boost=2&pt1_ie=99&pt1_filres=0.08&pt1_ipd=0.2&pt1_mbp=0.5&pt1_ce=58&pt1_te=75&pt1_egt=1550&pt1_ter=1.12&pt1_pw=27.56&pt1_bsfc=0.43&pt1_afr=11.5&pt1_wts=300&pt1_wd=83&pt1_wd2=74&pt1_wrsin=69033&pt2_rpm=3000&pt2_ve=95&pt2_boost=6&pt2_ie=95&pt2_filres=0.1&pt2_ipd=0.2&pt2_mbp=1&pt2_ce=61&pt2_te=73&pt2_egt=1600&pt2_ter=1.27&pt2_pw=13.42&pt2_bsfc=0.45&pt2_afr=11.5&pt2_wts=320&pt2_wd=83&pt2_wd2=74&pt2_wrsin=73635&pt3_rpm=4000&pt3_ve=100&pt3_boost=15&pt3_ie=95&pt3_filres=0.12&pt3_ipd=0.3&pt3_mbp=1.3&pt3_ce=69&pt3_te=72&pt3_egt=1650&pt3_ter=1.65&pt3_pw=20.16&pt3_bsfc=0.48&pt3_afr=11.5&pt3_wts=340&pt3_wd=83&pt3_wd2=74&pt3_wrsin=78238&pt4_rpm=5000&pt4_ve=100&pt4_boost=25&pt4_ie=92&pt4_filres=0.15&pt4_ipd=0.4&pt4_mbp=1.5&pt4_ce=73&pt4_te=71&pt4_egt=1650&pt4_ter=2.19&pt4_pw=25.6&pt4_bsfc=0.5&pt4_afr=11.5&pt4_wts=368&pt4_wd=83&pt4_wd2=74&pt4_wrsin=84681&pt5_rpm=6000&pt5_ve=100&pt5_boost=25&pt5_ie=90&pt5_filres=0.18&pt5_ipd=0.5&pt5_mbp=1.8&pt5_ce=75&pt5_te=70&pt5_egt=1650&pt5_ter=2.38&pt5_pw=32.62&pt5_bsfc=0.52&pt5_afr=11.5&pt5_wts=400&pt5_wd=83&pt5_wd2=74&pt5_wrsin=92044&pt6_rpm=7000&pt6_ve=100&pt6_boost=25&pt6_ie=90&pt6_filres=0.2&pt6_ipd=0.6&pt6_mbp=2&pt6_ce=72&pt6_te=70&pt6_egt=1650&pt6_ter=2.62&pt6_pw=36.05&pt6_bsfc=0.55&pt6_afr=11.5&pt6_wts=400&pt6_wd=83&pt6_wd2=74&pt6_wrsin=92044&
1 - 2 of 2 Posts
