1 - 4 of 4 Posts
http://cgi.ebay.com/ebaymotors/ws/e...Sell_LogicX&refwidgettype=cross_promot_widget
With this piston/rod setup along with arp head bolts would my y7 be able to handle my goals of 250-275ish hp?
I've search and seen that yes the vitaras have held up to 400 hp but I just wanted to be sure.
Also what kinda of machine work, if any would be required to put these in? or is it a drop in and go process?
Finally as far as an ecu, from what i've read my understanding is my best bet would be to convert to obd1 and run a chipped ecu my question is which ecu should i run if my motor is a y7 with the y7 head.
Thanks in advance for any knowledge you share. :TU:
if u bot the stock bore of pistons u wont need to do ne machine work and u would probably wanan run a chipped p28 with obd1
1 - 4 of 4 Posts
