1 - 20 of 22 Posts
98 civic
what is different from a Y7 block to a Y8 block? and what would i have to do to put my Y8 head on it
there is now difference in the blocks themselves only what goes in/on the blocks.
98 civic
like im prolly gonna get a cheap Y7 block and put the build in my sig then put my Y8 head on it. i guess all i am asking is what all would i need to do to put my Y8 head on a Y7 blcok
Curious George
'99 LX Civic Sedan
y8 block had a nock sensor, and not the same stamp :p
you will have little bit flatter pistons in y8 but lower compression height, it's IMHO the same fuckin' thing, about .1 CR. Everything else is the same.
yup same shit. im using a y7 block with my z6 head. plug n play,
^actually i think both blocks got stamped P2E on the bottom but the engine code stamp is where the difference is at
are you sure the y7 has an oil thingie in the block, the mini-me how-to i read didn't say anyhting about it...
I can't read...
if it's there, remove it. if not, then your good.
98 civic
ok cool so looks like im gonna be picking up a Y7 block and boosting the hell outa that so of a bitch
98 civic
remove the oil orifice out of the deck of the block, change your ecu, then your good. :)
what does it look like the oriface? and im running a P28 so that aint a problem
I can't read...
looks like this...
EDIT: and i checked. the y7 block does not have one of these.
98 civic
ok nice this is what i wanted to hear. now the build will be moveing again in stead of dead in the water
98 civic
1 - 20 of 22 Posts
