1 - 10 of 10 Posts
Title self explanatory. A friends AT eg needs one and l have a spare MT one.
I know from mt to at is pretty simple, but l couldn't find if the opposite is true or even possible.
Any help appreciated.
Discussion Starter · #2 ·
I also have a spare at p72 for parts if that helps
2005 Legacy GT
If you look up how to convert an Auto to Manual, I would assume the process is the reverse.
IIRC it involves cutting a resistor, so to convert the other way ... you'd have to solder in a resistor to the same position as the one that need to be cut?
Discussion Starter · #5 ·
I've spent the weekend looking into it and at the ECU, the AT to MT is easyer because it just bypasses the part that controls the transmission.
Apparently I need to swap the parts that controls the transmission into the MT ecu and do the resistor thing. But I dont knwo which one those are. =/
Asshole
Then it's a pr4 or someone put an at ecu board inside a gsr ecu case.
Asshole
I did not see you were from Brazil my bad. I wasn't aware there were automatic vtec b18c in other markets.
1 - 10 of 10 Posts
