booyah son! thats what ill be rocking as well. ill be using the Tial style, not the HKS style like you though :TU:ccfab said:me personally, im a ssautochrome wastegate man my self
i'm sorry for him. as i psoted flow and pressure are 2 factors the excternal outdoes the internals in. also the internals tend to have issues with exhaust carbon buildup around the flatter opening thus causing seal loss. when this happens, you get spiking. externals have a valve style which doens;t have this issue often (unless it's a bad design or a really rich running motor all the time)sohcturbo said:Siguy2 was running 26psi on an internaly gated 20g on his awd mitsu, without a problem, you need to have a good boost controler. And internaly gated turbos are usually mo,re expensive than ones that are externaly gated... once you buy a external WG you end up being aroun the same... I agree with the externals performing better though
oscarmayer said:i'm sorry for him. as i psoted flow and pressure are 2 factors the excternal outdoes the internals in. also the internals tend to have issues with exhaust carbon buildup around the flatter opening thus causing seal loss. when this happens, you get spiking. externals have a valve style which doens;t have this issue often (unless it's a bad design or a really rich running motor all the time)
Learn how to readsohcturbo said:I agree with the externals performing better though
I can vouch for this when I opened up the used t3 turbo to clean it. I had to remove a lot of carbon buildup around the flapper. nothing a wire brush and a dremel couldn't take care of though.oscarmayer said:also the internals tend to have issues with exhaust carbon buildup around the flatter opening thus causing seal loss.
ryan89crx, lolccfab said:ryan 89 whats your hmt name?
