My shizz just showed up.d16rice said:The following parts have been sold:
Arm rest
Altezzas
Antenna
Eyelids
Bump for a good seller.
Arm rest
Altezzas
Antenna
Eyelids
No, only the front ones. I tried removing them, but they turned out to be more work than they're worth. I wanted them for my hatch, but just ended up buying bran new ones off of eBay for $30 shipped.v-tecivic said:since you had a lot of 96-00 4dr parts, i wanted to know if you had both outside rear door handles(without the keyholes).
thanks-andrew
I'm only going to part out MSD ignition if someone buys the distributor first.damn, you have a lot of ish...
how much for just this..... MSD S.S. blaster coil & the coil wire... thank's
cool, please keep me in mind if that happen's... thank you, BrianI'm only going to part out MSD ignition if someone buys the distributor first.
Otherwise it's sold as a whole.
I have not received your pm :neutral:You've got a pm
