1 - 6 of 6 Posts
Interesting A/C Diagnostic, Discovery that has me confussed
Customers Complaint A/C blows warm. Common.
Verified it blows warm.
So I hook up a A/C machine and there's roughly 80 psi on the high and low side, fridgerant in the system. Turn on the A/C and the clutch doesn't engage. Okay, I do a quick check of the fuse and swap the relay. Nothing.
I do some reseach and don't find anything good. and check power at the a/c compressior with the switch on. 14 Volts. A/c Compressor housing has a good ground.
With 80 psi, it shouldn't trip the pressure sensor, obviously if the compressor has 14 v. I called a compressor.
Now here's the strange part:
When I recovered the system charge there was only .2 lbs of refridgerant in the system ?????????? Does pressure not equal how much of a charge is in the system? Do you have to recover the system to everytime?
\/Your Mom Was Here\/
Vibe GT
What kind of car is this on? Also I did a Dodge Caliber alternator and the AC compressor wouldn't kick on after and I had to reset the ECU for it to work again... new cars do weird shit.
I do a recovery on the system everytime just to make sure to get all the moisture out of the system and try to hold a vacuum on it for a while to check for leaks.
Also you may be looking at a expansion valve problem is the pressure on both sides is equal, but I have seen compressors go bad and do similar things.
See above...
^Yeah, new cars and all of their electronic do-dads. Boo!
Oh wait, I drive one of those cars! LOL
06 santa fe.
the hub/clutch was locked up. Replaced the compressor. operating pressure oh, 150 and flucuating between 20-40 on the low side. held vacuum. I let the system sit for a few minutes and it was around 20 and 100/
I thought pressures should equalize. and that was a good reading. I'm talking from the stand point of a quick diag. intial pressure reading.
Nope. Reading the static refrigerant pressure tells you nothing about how much refrigerant the system has. It only tells you the system has some refrigerant.
The pressure equalizes slowly. It may take 10 minutes or so.
1 - 6 of 6 Posts
