1 - 19 of 19 Posts
being that its tax season one of my plans is to upgrade from my DSM T25 and get a DSM 16G so I was wondering what size intercooler would be enough. right now I have a 27"x6"x3" with 2.25 inlet and outlet.
That should be big enough. If you have the stuff to datalog you should be able to watch your iats and that should tell you if you need to upgrade or not.
I say fix the front end first. Lol!
Considering how many guys have pushed the original DSM sidemounts to silly power levels, that intercooler is more than enough. That's about the same size as the one I will be installing onto my CRX with essentially the same setup.
the car is in the body shop getting a full do over + sunroof delete, new trunk floor and windshield..
for the engine I picked up a Y7 valve train real cheap to put in my Z6 head. I will get a regrind on the cam. is the delta 272-2 good for a daily driver?
why not stay with the z6?
I will be running the Z6 head, but without VTEC. just keeping it old school and simplifying things.
??? I've seen lots of posts about using Y7 cam , gear and valve train in Z6 head for non vtec setup....
Yea thats what I was thinking lol
Lol great minds think alike.
That's cool it's all getting fix.
So vtec head with non vtec cam?
why?
He probably was told that tuning on VTEC is too hard. It can be done and he would benefit from staying with the z6 valve train. Won't he need to have the cam caps line bored or does it involve just swapping the rocker arms?
Discussion Starter #15 (Edited)
Yeah, I am running the z6 casting with y7 rockers. Would not recommend. The y7 cam is ridiculously small and big cams run out of thread before you can adjust the valve lash correctly. Better off stay with a stock z6 head/cam/rockers.
out of all the posts ive read from this forums and others it never mentioned anything about problems with valve lash adjustment
Discussion Starter #16
I just want a simplified non vtec setup. from what ive read you keep the stock cam caps cause the bores are machined to match the head. it involves swapping rocker arms plus its spacers and springs , cam and gear.
Discussion Starter #18
would have gotten a PM3 head but I'm runnim running a shaved Z6 head with vitara pistons. i wanna keep the compression where its at
1 - 19 of 19 Posts
