1 - 20 of 25 Posts
Ok soooo i just wana dial in my turbo kit and was wondering wat is the ideal charge piping for a turbo kit?? i heard people all the tip that see like 1.5 or 2 inch and say wow thats kinda small.. but in my mind :idea: u should run the "hot side" the same size as the outlet of ur turbo and after the intercooler "cold side" should be the size of ur throttle body ?? correct me if im wrong but its just runnin threw my mind....
i would think the cold side should be bigger than the hot side. but i would just go with the same size 2.5" works well.
R2.....Zap Balls
I have 2.25" on both the hot and cold side. It really depends on your set up and goals.
I personally run 2.5 inch for the coldside and 2.0 for the hotside.
2.5 all the way around will work no problem.Honestly for most of the setups here anywhere from 2.0-2.5 is fine.
thanks again...
i cant believe how fast i get a response on this site... honda-tech taked like 2 weeks and they just beat around the bush or talk shit...
d-series.org FTW
1 - 20 of 25 Posts
